Formulaonehd
NWZ - The storm is here
Hi all
This has been discussed before but my 93 4spd cruiser has been behaving odd with gear changes after a lengthy stint in the garage (not being used) prior to me buying it .
I suspect the solenoids are stuck and ordered some direct from bargwarner. What I wanted to ask is what rpm should my truck be when travelling at 60mph (100kmph) ? Mine is currently showing about 2600rpm at that speed and to me that says it's stuck in 3rd gear ?
Other symptoms include :
1) When cold it thumps into reverse
2) changes up a gear from take off too quickly and I suspect it is going into 3rd from 1st
3) very harsh kick down back to 1st gear when you plant your foot .
4) won't kick down gears at higher speeds say over 80kmph
My dash lights are working fine as we re-plugged the old barrel connector near the starter motor
Again I suspect the solenoids but I'm not sure what gears I am in to confirm this
Cheers
Cheers
