Hey guys,
I'm changing my clutch today and am slowly moving through the directions in the Toyota repair manual.
I've got the shift lever out, and removed the transmission cover.
I now need to drain the transmission and transfer case but I don't know how. The manual just tells you to "raise vehicle and drain out transmission and transfer" . I presume I need to elevate the vehicle so the transfer case fluid will drain. Any feedback would be appreciated. EDIT: You don't need to jack the vehicle up. Remove t case and transmission fill plugs first to prevent them from sticking. The remove the respective drain plugs.
EDIT: Labels now correct
Thank you,
Fj502
Thank you,
Fj502
