transmission dip stick marks
Houston, TX
I'm low on fluid. The low/high HOT marks are about an inch apart and my fluid level is about an inch below the low mark. I don't want to overfill. Does anyone know the amount difference between the low and high marks?
I have a 1993, A442F.
You know that you need to measure the oil level wail the engine is running ant hot and the transmission is in neutral?
Yes, I drove it 30 minutes to work, put it in park on level ground and checked the fluid with engine running.
It goes in slowly via the dipstick and narrow Funnel. With it warm and running add fluid a few ounces at a time and you'll see how much progress you are making via the dipstick. It's super smelly so wear disposable gloves.
I'd put a half quart in and drive the 30 minutes back home and check it.
I did 1/2 quart and it almost made the low mark. I think another 1/2 quart will put it in the middle between the low/high marks.
Added another 1/2 quart and it put me between the low & high HOT mark. So for future reference, I think between the low & high marks is about 3/4 - 1 quart of fluid.
I don't think I have a leak. I just bought this 6 months ago and just got around to checking the transmission fluid.
