transfer case whine
When driving in low gear I have a whine from the drive line. I belive it is the transfer case. Everything works great. It has always done this. Oil is good and i change it every year. The sound is not terrible just very noticeable in low.
Today it dawned on me the I think it is VERY faint driving slow in high gear now. You can only hear it very low with windows up and radio off. Almost like the little fan belt pully when it was worn. Just a slight whine in the high gears. Not really worried about it becouse it is so faint. But would you guys say this is normal or is it bearings in transfer case getting worn and old?
If I had to do a rebuild of the transfer in a year or so it woulld not be so bad. I could toke the opertunity to put some gears in.
Do you have a DC drive shaft?
I believe every transfer case I’ve had whines in low gear, escpecially when the rpm’s start to climb! Not sure if this means it’s ok, but, knock on wood I’ve never lost a tc. Good luck
A lot of transfer cases have straight cut gears, these are noisier than helical cut. Mine is also slightly noisy in low, I had my old transfer case in bits a couple of years back however, I cannot remember the gear type.
Regards
Dave
Totally normal to hear whine in low range.
It’s an all gear driven transfer case so some gear noise in either range will be normal. Sound deadener and extra insulation helps keep the noise out of the cab.
