yes I canCan you take pictures and narrow down where it’s leaking from?
where both the front and rear drive shafts connect to the transfer case and where the speedometer cable attaches as far as I can tell those are the main 3
yes we replaced all of the o-rings and seals and applied lube to them before putting them back together however Im not sure if they are pitted or grooved but is it possible that they were blown out by pressure or if too much fluid is applied will it blow out the seals or cause them to leak and i probably will take it back out and recheck so there will be more picture laterDid you apply a bit of gear oil or lube to the seals before installing the output flanges? Are the sealing surfaces of the flanges grooved or pitted?
The speedo gear is sealed with an o-ring. Did you replace it? Old o-rings dry out and shrink.
When I took those pictures it was already empty I went to drain it but not much came outEmpty in 3 days or needs topped off? From the pictures you posted it doesn’t look to be leaking that much.
Maybe I'm going to look at it againHow did you go about setting the preload on the output bearings? Without sufficient preload, the rear seal will fail quickly.
I have removed the parking brake assembly and the seal seems to be bent badCan you take pictures and narrow down where it’s leaking from?
