Transfer Case Trouble
X2 what @65swb45 said. That’s a shim. Also, like @65swb45 asked , how did you set the pre-load? The FSM will show you how to do it using a pull scale.
Also, while you‘re there, check out the shaft on the parking brake drum. It sometimes develops a groove where the seal in the speedo housing rides around it. If it is grooved significantly enough it won’t seal. @65swb45 Can hook you up with a housing machined to take a double seal.
Flip the entire unit over. The seal is one the other side where the drum slides on.
How did you go about setting the preload on the output bearings? Without sufficient preload, the rear seal will fail quickly.
Forgive me but could you elaborate on pre load unless you mean how did I set the parking brake
I set it on the second notch on the
I set it on the second notch on the adjustmen
Here's what a grooved surface would look like.
Also, what @steffan is important. If the seal between the transmission and the t-case is bad, gear oil will go from the t-case into the transmission. Check your transmission fluid level. If it comes shooting out, you‘ve got your answer. In that case, you either need to replace that seal or use a bypass hose (connects the fill on the t-case to the fill on the transmission).
I have a bypass hose running in between them already but yes when I get it off I will check the seal between the trans and tcase
