Transfer case damage - what breaks?
Hmm...yes, I see the similarity...
I removed the transfer case rubber harmonic damper years ago.
Been driving without ever since.
Any sound / vibration difference it was supposed to make was too subtle for me to notice.
Being old hard rubber might make it ineffective at it's original purpose.
It's supposed to lag behind at a certain frequency, sort of counter vibrating.
@weigellj
Regarding the possibility of tied down break proof transmission mount on the 80, if you hung up with a lot of weight on transfer case.
Found this thread on the 100 Series transmission mount.
Has good photos and part number.
Would require a fairly big hole bored on the top plate of the cross member to clear it.
Concern over structural weakening? Maybe, not sure. Weld in reinforcement?
Can't tell if the shape and mounting bolts are otherwise compatible between 80 and 100.
Would be easy to tell with both in hand.
> Tied down break proof transmission mount on the 80.
Actually, this is too easy to sweat about.
There's a big gap between bottom of transmission and top of mount.
Fab a strap sort of thing wrapping over top of mount and under crossmember, a loop all the way around.
No scary structural mods needed.
You have got me so confused, so you want to tie your 80 series down. That way it can't leave the driveway and hurt its transfer case?
@weigellj
Regarding the possibility of tied down break proof transmission mount on the 80, if you hung up with a lot of weight on transfer case. - I (and you) don't want to tie it down so to speak & you still want the rubber to do its job and flex a little - all the weight of when it wants to play turtle - goes to the frame/ homemade crossmember. Tcase and most of the tranny can't be touched they way I have it put together.
Would require a fairly big hole bored on the top plate of the cross member to clear it. - Not worried, crossmember is all plate now is all custom - a hole in it can be reinforced/cut if needed.
Concern over structural weakening? Maybe, not sure. Weld in reinforcement? - See above
Can't tell if the shape and mounting bolts are otherwise compatible between 80 and 100. - Will know more this weekend when I try to do it, tcase side should be the same, Not 100% sure on the crossmember side (I think its the same) or "bolt" hole
Well, you know, I was thinking like one of these -
Then I can tie down the Cruiser in the front yard to guard the front door, but it can't go running off around the neighborhood and getting high centered in the neighbors raised square foot garden.
@weigellj - I'm with you on the mount still flexing and doing it's normal job - but constrained.
Looks to me that the 100 series mount does that.
I see other ways to do that now, but wasn't aware at all, until you brought it up.
I do think that what happened to you was a rather unusual extreme case, but still, can be insured against with relatively minor effort.
Looking forward to seeing what you come up with.
@LandCruiserPhil - I suppose it makes sense that you've seen some transfer case level action, since you sort of "raised the bar" with your Rock Rails. The increased clearance, as compared to frame mount sliders, puts the action up higher in your undercarriage, allowing you to slip over higher stuff before hanging up. A nice advantage. But, of course, now the transfer case becomes the "low hanging fruit" so to speak. Still, you must be picking your fights (lines) pretty well to have avoided getting bashed in rocker panels.
Rails have done the job well over the last 7 years plenty of rail dents with no damage but zero side protection is the trade off. It will be interesting going forward how things change with the new set up. One of these days I need to build the boat sliders so I can run the rubicon without worries.
Side note - Like others Im trying to figure out what exactly you are wanting to accomplish?
Phil, learning from experiences that I don't personally have, in order to fine tune what I might go through the trouble and effort to design and build for myself. Possibly to share the results, for better or worse, with the Landcruiser community. Possibly similar, at least in some ways, to what you accomplished with your Rock Rails, which, I think, gave a more nuanced understanding to "how much is really enough?". Sometimes - less is more. No?
I’m of the mind that if you think you might get into the sides of the truck, check out sliders. White Knuckle are great and take quite a bit of abuse and soldier on.
I’ve run pretty challenging trails here in AZ and not gotten into the rocker panels. I’ve also run rather tame trails and gotten into the rockers, usually on the outside edge of the body, near the doors. So it totally depends on the terrain and what you want to do with the truck. Sliders won’t protect against everything as you can see, but that also depends on what you run.
I didn’t have sliders for a few years, there were times I had to force the doors open and times I had to take measures to make sure the doors still opened and closed without issue. Now I have sliders and I enjoy them, despite their trade offs.
Bonus- your truck qualifies as farm equipment for tax purposes!
(I'd put a red circle around the plow option on his slider picture, but I'm too old to know how to do that.)
A lot of people worry about how long their beloved vehicles will last - how many miles till the engine wears out, etc.
For @richardlillard1, I don't think that's the concern.
Rather, his truck will steadily wear down, until finally, one day, it will be a small nub of rounded metal that will fall into a crack between two rocks on the trail, never to be seen again.
Then he can buy a Jeep.
