tranny issues
hillbilly desert rat
my tranny has a funky shift to it some times ... when i check the tranny fluid the level on the stick never changes hot or cold ..
the shifting is slow when i accelerate slowly when i put my foot into it the slow shift is not noticeable ..
i have replaced the fluid recently.. i just drained what was there and replaced ... no shavings on the plug ..
the fluid problem has been there for a while the shift thing is fairly new ..
do i change the fliter .. and any tips on doing that would be helpful
thanks in advance
91 80
Have you adjusted the tranny cable thats connected to the throttle body?
There's no filter to change, toyota use a screen that cleans itself when you drain the old fluid, i assume your cheking the fluid level with hot engine & when it's running either in park or in drive with an assistant with their foot on the brake.
Joinerman over the pond
Partially incorrect. There is a screen, however on older trucks this screen will become clogged with clutch particles over the years due to neglect and not changing the fluid. The screen can be removed, washed, and replaced. You will most likely find a good amount of sediment on the bottom pan when removed. This sediment can be disloged with a fluid flush and block valve passages internally.
With a tranny of unknown maintenance, I would drop the pan and clean as much as possible. Put it all back with fresh synthetic fluid and see where you are. This has little cost outlay and can potentially get you back to where you want to be. However the opposite can also be true.
should i just add the synthetic with the old fluid not all of the fluid will just drain out ??i do not want to do a flush i have heard to many horror stories about that procedure ..
so just clean the screen and pt it all back together .. with a new gasket of course
I think I'm having the same problem. I just adjusted my throttle, a little peppier, I like it. However, now when it shifts from second to third, it "goes to neutral". Otherwise, everything works OK. But it was after I screwed with my throttle. Or maybe just coincidence because I drove home in the woods last night and didn't drive it until this morning after I changed the throttle...
When you drop the pan make sure you have a catch basin under it. It will drip fluid from the valve body for quite some time and is a messy job, but not difficult. The FSM outlines the whole procedure and then some.
I believe I am having the same problem with the kick down cable on the tranny. I had messed with the cables when I replaced my valve cover gasket and ever since it doesn't shift like it used to. If anyone has an actual procedure I would love to know it. I also have checked the FAQ.
