Tranny Cooler Advice
C'eh N'eh D'eh
Are all tranny coolers created equal? OEM - Generic Brand X or is there something above and beyond out there?
A442F Tranny.
Do you have a separate tranny cooler or is your cooler within the main radiator?
Or maybe it's the oil cooler that's in the rad?
Anyway a cooler is a cooler. Just a bunch of metal to dissipate heat. So if you really have the need for changes, then you can experiment.
In general the quantity of fins (apart from the overall size) defines the ability to dissipate heat. But make sure that the fins are not too dense. There is some point where too dense radiators just don't move enough air.
As per http://www.automatictransmission.com.au/release.asp?NewsId=12319, all tranny coolers are not created equal, the type that came out on some 80s is better than the 100s IIRC, size of cooler is revelant, depth of cooler not so relevant. IIRC the multi crosflow is better than the serpentine as it slows the oil flow down. There may be more info on the above site if you ferret around
you don't have the 80-style OEM cooling? or do you want to add something?
No they are not equal. If you are going to add one, get the B&M cooler. Talk to any speed shop in your area, they will know what I am talking about. However, I thought the 80 series cruisers had an external cooler, apart from the radiator. If not, and overheating of tranny fluid is an issue, go with the B&M. I put one on my FJ 62 which is Toyota's first automatic tranny in a Landcruiser.
I bought a Tru-Cool Max LPD4921 for my 1990 HDJ81; it is 6"x23"x3/4"; 30,000 GVW rating; 34,000 BTU rating; with cold weather bypass valve. I'm having ATEB install it next week.
cooler details at TRU-COOL LPD Brochure (large PDF)
-Steve
-Steve
This was recommended to me before also - I'd be interrested in hearing how you like it. I'll check into the BM units also.
Thanks for the inputs.
The best recommendation for an aux tranny cooler is to not use zip ties to hold it to the A/C condensor or radiator. Either fab a mount or have someone fab one. I fab'd one on the aux B&M cooler I added to my '62 that mounts to the bolts holding the A/C condensor. That way it gets the benefit of the condensor's rubber mounting grommets.
This isn't in an 80, but it is an 80 transmission. I used a Fluidyne DB-30900. It has a built in fan, and is nicely constructed.
Sorry for the crappy picture. It is just behind the battery
Ryan.
