One inch of pedal travel is too much. Adjust the pedal to 1/8" and report.
Mark, you are one smart cookie! If I can remember this I will have learned something today!If you get the pedal and the T/O adjusted properly and it is still a problem, unfortunately the odds are good that your input shaft is binding on the pilot bearing/bushing. Most people don’t pay nearly enough to checking those tolerances before installation. And with an early Chebby conversion, it’s entirely possible that they used a bronze bushing that the I.D. ‘shrunk’ on during installation, causing the input shaft to get pinched.
No chevy conversion on thisIf you get the pedal and the T/O adjusted properly and it is still a problem, unfortunately the odds are good that your input shaft is binding on the pilot bearing/bushing. Most people don’t pay nearly enough to checking those tolerances before installation. And with an early Chebby conversion, it’s entirely possible that they used a bronze bushing that the I.D. ‘shrunk’ on during installation, causing the input shaft to get pinched.
