Gents, I have two forks/throwout bearings bushings. I am trying to figure out which configuration to use. I am swapping a 3 sp with a 4 sp. I have the correct bell housing and a new 4sp flywheel and clutch kit.
The fork/bushings are different.
Which should I use. The cast iron fork does not have clips to hold the TO bearing to the fork, but might not need them. The pic is below. What are some thoughts? I will swap the new bearing to the correct bushing.
