tranny and t-case gasket
I don't even bother with that thin paper gasket, just used a smear of the FIPG instead.
I used both a gasket and some gasket maker sealant. A little overkill doesn't hurt
Ok i was looking for some info about my tranny t-case rebuilt.
Then i read everything in FAQ and on the Search section.
So i will put everything that i think can help some of you.First time and don't want to look for input like i did .And hope this will go in the FAQ .
Sorry for the miss spelling and yes i copy/past from thread (easyer for me then trenslate ) My english is not good as my French so again sorry for that!
I will ad stuff from what i have day after day.
At firt look for the leak.
Be warned there are many places where the oil may be leaking from and for the most part the evidence from these many source points is found on/in/near the inspection cover. Clean up the oil and then inspect the following areas:
1) Valve Cover Gasket
2) Push Rod Gasket
3) Rear Main Seal
4) When doing the Rear Main Seal there are two other areas that you should look at. One is a galley plug with a very large allen head and the other is a push plug for the back what I think is the camshaft. Leaking from these areas is rare.
5) When replacing the rear main buy an OEM gasket.. I had to do mine twice :(
6) Do a search on the oil galley plug that us just in back of the #5 cylinder on the head. Lets hope you are not leaking oil from there.
LEAK :
https://forum.ih8mud.com/60-series-wagons/113830-what-well-whatever-its-leaking.html
https://forum.ih8mud.com/60-series-wagons/326553-motor-spewing-oil-here-what-why-arrgh.html
https://forum.ih8mud.com/40-55-series-tech/191622-oil-galley-head-plug.html
https://forum.ih8mud.com/60-series-wagons/351460-my-first-galley-plug-fix.html#post5161284
https://forum.ih8mud.com/60-series-wagons/226408-5-galley-plug-tap-broke.html
https://forum.ih8mud.com/40-55-series-tech/200299-tracking-down-leak.html
https://forum.ih8mud.com/40-55-series-tech/486218-timing-cover-bearing-crack.html
https://forum.ih8mud.com/40-55-series-tech/78749-oil-pan-side-cover-gasket-stuff-faq.html Thnx Poser
I found a great way to slide the t-case on to the trans without destroying
the shaft seal..
two bolts cut off and used on the top right and left trans bolt hole and slide the case on then throw in a couple lower bolts- unscrew the top bolts and replace. easy fast and give you the insurance that you did not ruin the inner seal.
