- Joined
- Jun 21, 2011
- Threads
- 238
- Messages
- 22,267
- Location
- Redding, California
- Website
- trail-tailor.com
- Thread starter
- #181
Here are some close-ups of the clearances on mine:
Front
Rear
Thanks D!
J
Front
Rear
more pics trying to demonstrate u-bolt positioning...
J,
The slider is following the lower rocker edge perfect in the above pic, pretty much like all the other pics posted.
J, if you're not happy I will refund your money along with the cost of the powder coating (please PM/email receipt for coating) Box them back up and take to fed ex, I'll give you my address to ship them back to me at your cost and I will gladly take them and install them on my own 100. Saves me from having to build another set before the move.
J
...Any more suggestions?
I live in Denver and have the same set of sliders if you want to meet up to see where they mount, I'd be happy to do so.
You guys may be over thinking the issue. This is a super easy fix. Just stick a washer between the slider and top of the frame and then retighten the u-bolt. It will pivot the slider out and down a hair. Add/stack washers until you get the desired gap. If you add them across the bottom of the frame it will push the slider up into the body. Add them at the top of the frame and it pushes the slider down away from body. You are simply using them as shims. My white knuckle sliders were very similar to yours and were too close for my comfort up at the front. I added one washer on the passenger side and two of the driver side to get everything perfectly level with about a 1/4"-3/8" gap all the way around. Took maybe 5 minutes of my time and about 20 cents in washers.
I wrapped some duct tape around the lines in any places they made contact with the frame mounts. Not sure if it was needed but if figured it couldn't hurt. I was not doing it for damage prevention purposes; I was just afraid the lines would now rattle and they would drive me nuts.Random question, are you guys doing anything to prevent brake lines from rubbing the ubolts? Assuming your mounting locations calls for u bolts to be slid under brake lines. Any concerns with rubbing hole in the lines?
Gotchya. I used some 1/4" id fuel lines wrapped around the brake line but I am concerned they'll just hold moisture and rot over time as I am smack in the middle of the rust belt. Lately I was thinking some flexloom as the would let the lines breath.
This ^^
I was about to suggest washers also. Pick 1 & 2 on post #184, is that the front U bolts? If so, you may need longer ones. Then add washers to adjust the slider up or down as needed.
Do you have a lift, tires, etc?mine fits in my old 1920's garage with no issues. it's about 4" from the roof of the car to the top of the rack.
Makes sense to me. If you need 3 washers of movement then adding a washer or two to the middle is probably a good idea. I doubt you will need that many washers. Probably two at the front and one at the middle will be perfect.Pics 1 and 2 are the rear and middle mounts, respectively. Pic 3 is the front u-bolt. Washers would fit there. I had considered spacing it out with washers but didn't know if it was advisable. I'll play with it a bit more and if all else fails add some washers. If I add 2 or 3 washers to the top front u-bolt do y'all think I should try to throw 1 washer on the top middle u-bolt (if I can fit it) for a more gentle transition from rear to front?
