- Joined
- Jan 31, 2006
- Threads
- 44
- Messages
- 909
- Location
- Greenwood, MO
- Website
- www.tornadoalleycruisers.org
Erik and I are both getting our ham license. There is a Hamfest put on by the Shriners April 20th. There will be testing administered at 0900 that morning, that is when we plan on taking our tests. Then we can wander around and check out all the gear. http://www.hambash.com/
If enough people get their license this option will be open for us to have better communications on the trails. If there is enough interest in it, we can probably get a study session put together before the 20th.
Bob, as for setting up a repeater at base camp, I'm having a hard time finding info on this and have a few questions I hoped you could address. Everything I read about cross band repeat is to set up a mobile to retrans with a hand talkie so you can use a UHF hand talkie to hit a 2m repeater, thus increasing your range even farther. What I had envisioned was setting up a mobile as a base station at camp set to RX on UHF and TX on VHF, both on unused frequencies. Then the mobile dual band rigs can set up to TX on the UHF freq and RX on the VHF freq so that a rig on one side of the park can hit someone on the other side of the park by using the camp repeater. The other issue brought up is the legality, since if I set the repeater up, my call sign won't be broadcast when the repeater retrans someone else's transmissions unless i get a mobile unit that will broadcast my call sign in CW. Also if no one is at camp, the repeater would not have a control operator, so again, another legal road block.
The prospect of all the extended range and possibilities is exciting, but there is a lot to learn.
