TP system Carb help
Austin, TX
I've been trying to diagnose a backfire during deceleration on my 1978 fj40 for a while now. During my process of elimination, I have turned to the Emissions Control Repair Manual thinking I had a crossed vacum line or something else going on. While reading and trying to understand how the TP system works, I noticed the diagram vacuum ports don't match what's on my rig.
I think the PO must have had someone work on this rig and installed the wrong carb. Here is a pic am I correct ?
Can you find a date stamp on the carb?
Here’s some threads that may have related info.
78 running rich Carb setup???
78 FJ40 California Carb/Vacuum/Emissions setup
The stock US-spec '75-78 Aisan carb was jetted too lean to run good when new. Factor in today's "gasoline" with oxygenate additives and they are waaay too lean. Dunno about new jets, but drillbits in the 1.45-1.50.1.55 range are readily available. Just sayin...
Yeah, those are stock slow jets for 77-78 USA carb. They are too lean. Drill them both to .85mm.
As a clear answer: the best overall carb would be a 75-77 US carb, desmogged & tuned. The 78 carb is a little smaller, so might be a limiting factor on top of an engine w/ headers.
If the vehicle must pass californika smog, then a stock appearing 1978 carb is the only choice. note that there are several different carbs used in 78 for FJ40, 55, 49-state, cali, hi-altitude...
I will look for a date code tomorrow. I don't think it's running rich. I've checked the timing and it's 7 degrees advanced. I've sprayed around with brake cleaner and it doesn't change the idle at all. I haven't checked the vacum yet. I've replaced the check valve at the air rail. I haven't and don't know how to check the ABV. Running a Downey header.
Twenty some-odd years ago one of my locals called with a backfiring issue on his 40, same system. Drives the truck over. I open the hood and point to a loose hose. Then I point to the nearby cylinder with the exposed nipple that is missing a hose. I say " You see that cylinder?" Him: "Yeah, what is that"
Me: "It's called an Anti-Backfire Valve!" So I attach the hose, problem solved, and tell him to go get me a hamburger.
Dave, your ABV is 40 years old. Don't overthink this. Chances are, it is your problem.
It looks like everything is hooked up correctly now. I get movement on the tp diaphragm but I need to get a vacuum gauge to test it. I did find this was missing the washer behind the clip. So i stole one from my extra carb and hooked it back up. Chasing down this backfire is a PINA.
Do you have a working one? Or can i fix this one?
There's a pic somewhere on the forum of a box of about 20.
They're floating around somewhere in the reorganization.
...That said, I think the issue could be avoided if you had a permanently mounted vacuum guage so that you could watch for the signs of moving valve seats [flickering reading on the guage] and stay up on your valve adjustments.:)
...I run dash-mounted vacuum guages in several of my rigs, so I have emperical data to prove otherwise.... :)
Time for an “emperical data gauge” and you best cover those exposed nipples before you roll into Mark’s Offroad. Or just bring extra money for cheeseburgers:D
I have two. One from the restoration and one on California Gold. Vacuum works fine and is strong. Both ABV's are bad like you said. I guess I'm going to have to make a IN-N-Out run again :) There was no need to blow thru the inlet, visually I could see the seal was broken by looking into the inlet. :doh:
Isn't the ABV closed when high vac (coasting decel) is applied, but open when vac is low? (rhetorical question)
If yes, then the valve should appear open during engine off inspection.
Found the pic December 21, 2016
