Hello,
I have a 1975 with 2F stock and Asian crab.
I have been working on this forever now. I have read a lot on this site with trying to find the source.
The problem starting happening when I would accelerate the car would sputter and not get any power. Sometime it would go away and other times it would never accelerate. It would also backfire on occasion and when I would turn the car off it would rev up and then finally die when the keys were out.
I have replaced, plugs, checked the compression on the engine (all good), replaced fuel filter, rebuilt fuel pump, replaced intake manifold, rebuilt the carb, replaced some vacuum lines, replaced starter with Denso from mid 80'c cruiser, and has a new battery as well.
I followed, I believe it was Treeroot's write up, and when I cover the carb with cardboard it will shut off and does so with out reving up. However I still think I have a vacuum leak because when I try to tune the carb and adjust the idle mix screw it does nothing. On top of this it seem every time I try to start my engine, after a few days sitting, I have to play with the idle speed and idle mixture screw to get it to turn over.
When I put a vacuum gauge on the engine (brake booster to carb) I get different readings depending on the day. I'm in Chicago so if it was new and perfect I think it should sit around 18. Now it will be between 15 - 17 depending on the day. Steady at that reading during that time. I will not jump around.
This weekend when I was trying to tune the crab with the vacuum gauge and tachometer it was reading 15 steady but the idel mixture screw had no effect on the RPM's. Never seems to speed up or slow down the engine when I turn it. The idle speed screw will effect the engine.
When the carb gets to much gas, because I'm pumping the pedal to get it to turn over, I noticed a bit of gas coming out of the primary throttle at the c-clip on the front side of the carb. The primary throttle plate is on a bar and that bar runs through the base of the crab and is held in place with a C-clip. I assume it leaked becuase the carb was flooded from me punching the gas pedal to turn the car over. Is that normal? Should the carb leak like that? If fluid can get out can air get it or is that a one way passage and normal?
