Bit of an cross over here. I have a Series 3 Land Rover fitted with a Toyota 3B. Engine is a fresh rebuild, and the alternator has been recently bench tested etc and in perfect working order (kind of) the external regulator hasn’t been tested/used properly since it was last tested properly over a year ago at the same time with the alternator
My issue is the alternator for some reason isn’t charging the batteries. At idle the voltage is roughly 22-23v, I found that the charge bulb in my dash was blown so thought that may have to something to do with my issue.
After replacing the bulb I turned the key to ignition (engine still off as it’s push button start)
And the bulb didn’t glow, I then attached an earth from said bulb to the steering shaft and bam the bulb glows bright. I had a Poke at a few things and did a continuity test on the regulator and it was good.
Looking for ideas on what it could be.
Cheers
Cheers
