Towing with an 80 Series
Land of Entrapment
Just want to provide my towing impressions related to a recent drive from Los Angeles to New Mexico – approximately 950 miles - for anyone considering using their 80 Series for towing.
I own a 1997 80 Series with 155k miles on the clock. Some background on the truck. The truck is in good condition and well maintained with a complete head refurb was competed at approximately 145k miles by a local shop with a long and very reputable history of Land Cruiser repair/maintenance. I drove the truck to LA to pick-up a newly purchased vehicle and rented a tandem axle U-Haul car hauler trailer (trailer weight approximately 2,210 lbs with maximum load capacity of 5,290 lbs) in LA for a one-way trip back to New Mexico. These U-Haul car hauling trailers have an automatic hydraulic surge brake incorporated into the tongue which I thought was pretty nifty. In past years I used our 2002 Sequoia with a TopHat tandem axle dove tail trailer which towed like a dream, but sold the trailer after the Sequoia was rear-ended and total. The Sequoia probably saved my daughter’s life.
The vehicle loaded on the trailer weighed approximately 3,800lbs and I had an additional 500lbs or so of spare parts and equipment in the back of the 80. For years I have used a Weigh-Safe hitch with a tongue weight gauge. Having an accurate read for the hitch weight is very helpful and provides great piece of mind…..at least for me.
For this trip I had the tongue weight set at 250lbs; felt well controlled throughout the trip.
I researched towing capacity and towing experiences for late model 80 Series, but didn’t feel I found any definitive information, so I was a bit concerned how the truck would perform. I have to say my 80 offered up a solid performance. It will not come as a surprise to anyone that the 80 did not provide V8 gas or diesel level of performance. Hills and inclines saw speeds fall to 38mph in some instances, but averaging 50 to 55mph felt comfortable in the truck and for the entire trip – and I mean like every mile – the water temperature gauge was pegged much pretty at exact mid point, and that included driving through Needles, CA in the late afternoon with 103 degrees registering outside. I do have airbags and inflated them to 35psi. The roads I drove were mostly in only average condition with many miles of wavy, and roughed-up asphalt, but 55 mph was a decent steady speed with a few under asphalt construction transitions and surface tear-down sections that were a bit hairy for moments, but other than that I rolled back home pleasantly surprised at how well the trip went.
Yep, 80 is a good "slow and steady" tow rig for loads under 5k pounds. Emphasis on "slow", especially in the mountains. I do not run airbags and I have soft springs, so it sags a lot under the tongue weight, but still feels solid and secure.
FYI, the stock water temp gauge on your 80 is basically an idiot light disguised as a gauge. If you see it move, you're already over-heating. If you plan to tow more with the 80 (or even if you don't), invest in a real water temp gauge or a scangauge or the like.
Some of us have kept and modified the OEM temp gauge per this thread:
But, if you're not comfortable with taking your dash and instrument panel apart and handling a soldering iron around sensitive and fragile parts, a scangage would be the better way to go, especially since your '97 is OBD II.
Thanks for sharing this. I'm thinking of towing a 3500-4000 lb airstream bambi up big bear this summer and am trying to size up if this is possible to do safely. My 80 is in great working shape even though it has 310k miles on it. I have a 3in ome lift on it.
I'm most concerned about brakes down the mountain and the first climb up it.
I'll take your post as a vote of confidence although i feel the need to use an overwhelming abundance of caution.
I've towed just about everything with both my 80's, from small trailers, teardrops, and pop-up tent trailers to a 4200lb boat, tiny house, and loaded car hauler. Whether in stock form or with upgrades like a 4" lift and gears, it's all been a struggle, especially when facing inclines. Most of these trailers fare okay behind th 80 on flat terrain, but expect challenges in windy conditions or uphill stretches. Personally, I've towed extensively, my 21ft, 4300lb boat. While I feel safe with it, the uphill battles and fuel inefficiency make me contemplate switching to a different tow rig. After a grueling 1800-milelast year , I’m considered adding a 200 or GX460 to my fleet to avoid the constant strain/drain of towing with my 80. Getting ready to do that 1800miles towing the boat again in June, so my mind will probably get made up then.
Love my 80 but would never want to tow with it.
I prefer to tow it 😂
Your Airstream is a lovely trailer, and it's curvy piece of air suck 😁 . It's gonna suck no matter how you slice it but as long as your cooling system is up to snuff, and the ATF was drain/refilled before the trip, you'll be fine. What are you doing to prevent the rear end from squatting? Obviously, you can forget about using OD!!
I used to tow a 2600# pop up camper from 5k - 10k and it sucked on the high elevation passes. Now that I have a turbo I can't wait to tow the same trailer to see what it feels like.
You guys are crazy. For all of its best-ever chassis, timeless styling and awesomeness, let's please admit that an 80 (even an 1fz-fe 80) is an underpowered dog -- add in a lift and some big tires and it's a doggier dog. Yeah, like the OP said, it'll tractor along just fine at 50-55 mph across the flat parts of the USA, but does that sound interesting? Get a super duty for that airstream.
Towing with a 80 😂
