Do you use your defrost? you should be able to disco the defrost grid, grab power there and then your light will be switched as well. just a thought
^ thisIs there a write up on this Phil?
I'm actually considering tackling this and I'm pretty sure what he's saying is to locate the Rear Defroster Relay and just jumper the 12v+ in and 12v+ out (to the defroster grid). This way there's full 12v to the rear (no defroster switch needed). Then after you tap into the defroster line in the rear, setup a on/off/on toggle to feed 12v to white or red LED strips.Actually when you jump out the defrost relay (relay control voltage is switched) you will have constant 12v 20A circuit to the hatch, as that is the way I did mine.
Hatch door activated
Switchable red - off - white
dimmable
^ this
Somewhere
Im on the road right now, search
Top left relay, driver's side kick panel.Where is the rear window defroster relay located? Wanting to tap it for my LED light project.
Honestly, it was pretty non invasive to grab +12 from the 2nd row overhead lamp. It's always hot, fused with the dome light circuit (10 amp), and doesn't effect any other system on the vehicle.Was hoping there was already power back in the hatch to tap into. What was I thinking. Thanks.
dimmable
Yes with more storage in the back. More sq/ft with the garage and covered storage than the housebeyond your cool looking cruiser...your garage situation has me even more envious. Is that two double garages with a sweet awning?!
