Too Far Gone?
@henrymski Where exactly do you live? Near me, you could drop your rig off at a rust repair place and, after paying about $600, have all the needling, wire brushing, acid etching/rust reforming and fluid filming done for you. I did that on my rig and I haven't seen any appreciable rust under my rig at all. At this point, I think that the rust has been stopped in it's tracks and I have a life time warranty.
I'd drive it until something fails- but certainly wouldn't put anymore $ into it.... and I'd start the search for a clean TX or SW rig that might need a motor...... is it locked ? ( didn't see that noted)
E
Yeah honestly doesn't look as bad as my fathers 60 which has spent the last 2 decades in Virginia, before that it was a Tejas truck.
As others have said, scrape scrape scrape and treat. I like the idea of sandblasting. Looks to my unprofessional but 'mud educated eye that some of the serious stuff is on parts that you can unbolt and replace with rust free units from a rust free area donor.
Keep it. It's paid for innit?
The fact that he did the HG job kinda seals it for me. It's totally worth saving if it's as he describes. Plus, you're right, a lot of that stuff will bolt off and then back on. I wouldn't try that this year though. I would get the big stuff knocked down and then start the oiling process and be sure to slather as much on the back side of all the bolts as he can. Eventually, with the combo of the oil soaking into the threads and then judicious use of heat and a gentle touch, everything can be loosened without breaking anything( I broke less than five bolts, total, all of them were really small). I got the fine thread bolts that hold the factory trailer hitch in place out without breaking any of them. Sure, it took two years and a bunch of dinking around to get oil pumped into the little holes in the frame back there, but I did it and by being patient, it really didn't require a massive amount of time. Probably only an hour or so, total, in five to ten minute increments spaced over several months. Those and the spare tire carrier bolts were the worst.
Get it cleaned up this year and well oiled and then start playing around with a propane torch and hand tools next spring and see what happens. If they don't budge, just oil them again(especially when they are hot, that makes a huge difference as the oil can migrate easier and the metal is expanded) and try again in the fall. Rinse and repeat until it's not a rust bucket anymore.
Also, the best rust eater that I have used is muriatic acid. I use it extensively once I have parts removed and can get them into a bath of the acid or brush it on. It's strong stuff though and caution needs to be used.
I certainly don't envy you guys back East!
It snows 4 months out of 12. That is about it.
My 91 has literally zero rust. Every suspension nuts and bolts underneath can be removed with just hand tools after 28 yrs. I really feel your pain....
Yeah, but you have a '91 though. I don't have to feel that pain. ;)
lol
you can feel your own pain when your head gasket blows. At least for my 91, i dont have to worry about it, and it moves just as well as a OBD2 rig. there ya go. For those 91/92 haters
Already done! I also have OBD1, so I get to feel the unbridled, nearly liquid, power of the 1FE-FZ without having all that fancy stuff clogging up my horses hooves. :p
as per your pics - replace your metal brake lines, metal fuel lines
and check out your lower rear heater lines underneath the cat heat reflector for a "wow i was that close to losing
all my coolant and popping my HG moment"
buy a needle scaler and then apply a gallon of fluid film
Thanks for the info, and who built the bumper? and what headlights are those?
