Too Far Gone?
I just refreshed the under carriage of my truck.
I pulled the rear bumpers and flaps off and went to town. Get a creeper some sanding disks and a plastic face shield . Take a weekend and do it. Spray the rubber with 303 protectant and don't forget to clean up any ground wires.
This is how much I took off using an air gun and compressor.
I think the biggest thing here is if you WANT to do the labor. That’s a lot of sweat for not a ton of return equity.
If you did remove the rust, are you going to continue to drive in the salt and set yourself up for another round of removal.? Underspray it and raise questions later?
Anything can be salvaged, but when it comes to rust, it’s usually not worth your time.
Just my .02
180* out IMO.
If he’s a casual user (yep) & not looking to stress it like a Pro4 class buggy, then rust control is still there for him.
We’re extremely spoiled out West, his rig is reality of a decades-old frame in the rustbelt or NE coast.
If the OP’s core powertrain is still ~90% like new, and his goal is just to mitigate rust for his next ~20yrs, then he can get there.
Yes, I “thumbed down” your reply......feel free to do the same :p
180* out IMO.
Its all good. Its just my opinion of course. I'm sitting here assuming that his 1994 drivetrain probably ISN'T 90% like new. I'd say most aren't by now.
Also haven't discussed the body panels. Those would be more of a worry to me than the underbody. I'm sure there are plenty in the rear hatch and roof. And that isn't rust mitigation, thats replace at this point. Nobody is going to replace those unless they WANT to take the time to do so.
I've had rusty rigs with thin sheetmetal before, (Unimog 406) and I'd never touch one again. Not saying an 80 is the same as other rusty vehicles, but I cringe at the thought of removing the bolt pictured above.
Truck has 196,000 on it. Still a baby. I've done the head gasket, the pain in the ass hose or whatever people call it, and all that stuff you should do. It has an idling issue that I've been chasing for a while, but I'm going to replace all the vacuum lines and see if that helps. They need replacing any way.
As for body rust, there is surprisingly little - the bottoms of the doors, some bubbles on the front of the hood. My secret is that I never wash it!!
You may find a shop who will sand blast and under coat for you. Check around. These trucks are getting tougher to find. I didn't see really anything too bad when I was under the one I have ( from 2005) and it's really the first time I've used any abrasives.
I found a guy who would have blasted the undercarriage of my truck for $500. but I decided to do it myself.
Dang man...a little surface rust and you guys want to crush it? I bet this thing is more solid than half the cars on the road near Chicago. And yes I know some of it is a bit more than surface, but I bet this thing is structurally sound as hell.
Hey now. There is some rust there, but no cracked dash from the sun, no cracked wires from heat, the clear coat is still intact.
I think this call would depend on how much you like the truck and whether you would take the job on yourself or pay someone to do it. Paying someone could get pricey but if you like a couple of weekends or so of hard graft and enjoy the truck I'd go for it. I've seen worse.
If I was undertaking the work the others have stated here to bring her back I'd also consider obtaining a bunch of the hardware and slowly start cutting out and replacing the bolts and bushings as time permitted.
I get some of the West Coast gang is spoiled, but daaaaang !!!!
-Clearly I worked in refineries where anything in the pipes wanted to burn or kill you if it got out, so I grew up (literally since any college break I could go whiz quiz & work all breaks) - so I grew up from ~19 on with corroded pipes & build-up welds or ‘custom’ gaskets/band-aid fixes to keep process running until a planned unit outage.
That & old muscle -era rides taught me to see potential & realistic timeline fixes.
With <200K on the powertrain & a reasonable service life of 10-15-20yrs, as long as you go crazy fixing it now it’ll serve you well as a sporting / Home Depot runabout rig.
And for really not a large outlay of $$$$.
Fix it, and keep it. —No question IMO.—
Yeah honestly doesn't look as bad as my fathers 60 which has spent the last 2 decades in Virginia, before that it was a Tejas truck.
As others have said, scrape scrape scrape and treat. I like the idea of sandblasting. Looks to my unprofessional but 'mud educated eye that some of the serious stuff is on parts that you can unbolt and replace with rust free units from a rust free area donor.
Keep it. It's paid for innit?
