The question I'm putting out is this...Is it better for the release/throwout bearing to always be in contact with the Pressure Plate or away from the pressure plate when clutch is out? Mr. T decided in mid 1984 that it should always be in contact.
FJ60s from 1/81-8/84 have a clutch slave system designed to keep the throwout bearing away from the pressure plate when clutch is released. The rod has an adjustment nut system on the end that engages the fork and a spring return that pulls the fork arm toward the slave cylinder. After 8/84, the slave is designed with a spring in the slave rod to always keep the throwout bearing in contact with the pressure plate by applying force away from the slave cylinder and pushing on the fork arm.
OEM Part # for the following parts are the same for all models it appears:
Release Bearing: 90363-52001-77
Pressure Plate: 31221-60020
Pilot Bearing: 90363-15004
Flywheel: 13405-69015
Clutch Disk: 31250-36343
Master Cylinder: 31410-60282
I did find a Pressure Plate for 1/81-8/84 production, part number 31210-36330.
Clutch slave for 1/81-8/84 part number 31470-60081
Release Fork for 1/81-8/84 part number 31204-60030
Clutch slave for after 8/84 part number 31470-60102
Release Fork for after 8/84 part number 31204-60060
So will the throwout bearing last longer if it is constantly spinning...always in contact with the pressure plate, or not spinning...away from the pressure plate when clutch is out but jarred into motion when it hits the pressure plate every time you engage the clutch? I don't often disagree with Mr. T but after reading way too much about throwout bearing chirping, I want to see what the consensus is here.
