I believe that's the infamous Greg rock that hosed his fender and hashed my rear passenger RW ring.
That's the one!
@kreiten thanks for the great pictures!
Thanks for the advice you definitely have a lot of 200 suspension experience . For now I’ll just keep saving hopefully I can just do it all at once the right way.Spacers will get you taller, but the stock shocks/springs are so soft the truck becomes wobbly. Don't want to be riding around like a jeep!
10mm front and rear will be fine with stock components, but much more than that and you start to get serious lean in the corners and a wallowing as you exit the turn.
I ran 2" spacers on stock shocks up front when I sent my Icons for rebuild. take the marshmellow feel of the stock suspension and amplify it.
I did it out of necessity, but definitely wasn't going to go wheeling with that set up.
If you were so inclined to upgrade your suspension in stages, I would go with 10mm spacer up front, then 2721 springs in back, then front coilovers and rear shocks.
definitely not the ideal way to do things, but it is an option.
I know Land Cruisers are awesome vehicles and you all are great drivers. Thought of you when I saw this.
