To CDL or not CDL
Monroe, GA
I’ve got a ’97 LC, with the viscous coupler. Shortly after I bought it three years ago, I installed a CDL switch with the 7-pin mod. Then, about three months ago I put an Aussie Locker in the rear.
Now, I normally lock the CDL, in Hi, as soon as I pull off the pavement and leave it locked until I’m ready to pull back onto the pavement. However, after reading some threads about steering response and axle wind up, I’m wondering if I should try just engaging and disengaging it “as needed”?
Also, FWIW, according to Wikipedia, the viscous coupling can send a maximum of 30% torque to the non-slipping axle.
Once CDL is engaged then you get even 50/50 power to both axles and if one slips the other gets 100% of power.
Keep doing what you are doing, once on dirt just hit that CDL bad boy and forget about it till you are ready for payment again.
I think the steering response and axle windup you are finding is related to front or rear diff lockers, not central. What you are doing is what I have found most "experts" and schools teach, off pavement lock CDL.
If you like pushing buttons, keep doing what you are doing. Personally, I have never found the need for the center to be locked in high range. I think Toyota got it right - just drive until you need low range, shift into low, the center locks and keep driving. Why over think it?
Totally agree with 60wag....!!!! I really believe the Toyota engineers got this wright....there is no need for central lock while in high range ...in fact quite the opposite.....locking the center can really have a negative impact on truck behavior above 30-40 mph....
regards
FWIW I l always lock my CDL on dirt roads. If you are "off road" you really should not be going that* fast anyway as you are on unstable ground and can not avoid a crash due to lack of traction. I have driven the same dirt roads at approx 30MPH both locked and unlocked and I can tell you that you have FAR more control when locked. It has to do with power to the steering wheels and reduction in sliding/slipping. I have had a few sketchy moments when I had to make quick reactions on blind corners because some tweeker decided his accord was a drift car and believe it or not have had to do this both locked and unlocked. You have far more control with CDL engaged, there's no reason not to.
There is a well known and respected off-road guy who is about 50YO and has dozens of videos on YouTube, he does a skid pad test at all speeds, some towing a "caravan" and the difference is amazing, cant find the video ATM but I will post when I do. This guy is European and does a ton of off-road expedition videos primarily in Aftrica FWIW
Just to buck the trend, the second switchback on black bear pass is a good example of when the ability to UNLOCK the CDL in low range is a good thing. Yes, you can do it with CDL engaged, but unlocking it gets you just that much more of a tight turning radius and on things like that it is appreciated.
I'd be very interested in seeing this.
Again, every situation is different and one size does not fit all. Certain roads/trails should be locked, certain ones don't need to be.
Here in the Northeast we have some very tight trails and you're constantly weaving around trees. I am usually unlocked, depending on the conditions/situation, to prevent the front wheels from plowing (understeer) and not allowing the tight radius turns that need to be made. In those situations an unlocked center is a wonderful thing and it would be a PITA to do it any other way. It also puts less load on driveline components.
Every situation is different, every driver is different, every truck is equipped differently. Making blanket statements like "as soon as you leave the pavement you should lock the center diff" is silly. I bring an umbrella with me in case it starts to rain, but I don't open it as soon as I leave my home regardless of the weather conditions.
The key is to LEARN how YOUR truck reacts to different situations and conditions.
Good answer.
