tires
norman, oklahoma
I have a stock 72 fj40. currently running 31x10.50's. is there a suspension system i can use to accomplish 35x12.5's. does this require cutting? are there any rubbing issues? what suspension an rims work best? im in the dark!
Welcome to Mud.
With a 4" lift you should be able to fit 35" but it may require a little bit of trimming if you flex it.
The follow companies make a 4" FJ40 lift althought there are others out there.
Skyjacker
HFS
BDS
Also check out the FAQ and search functions.
If you do a SOA you'll be able to fit 35's. I run the Toyo 35x13.5x15 tires with only the smallest amount of rubbing in the rear at full articulation.
what is the ride like? this truck is my daily driver. did you put on an entirely suspension? what rims? do the have to be offset?
Welcome to Mud!
If you used the search engine to search the 40 tech section (located upper right) you would have so much information to go on that it will keep you busy for a while... but you will be well informed.
Search for:
Lift
Which Lift
Spring Over Axle or SOA
I bet you get most of your questions answered there and anything that doesn't we can gladly help you with.
That said, a 4" lift will get you there, check out the vendors that support this site at the top right and quite a few offer lift kits.
Have fun!
Rezarf <><
A 4" lift is going to be a lot more stiff than a SOA (Spring Over Axle) conversion using stock springs. The reason for this is that that 4" spring is going to have more of an arch. Then again Cruisers aren't known for there on road ride quality. Well least not the FJ4s0
Wheels I believe they have a 3 1/2" backspacing. You can also use wheel spacers if you find a wheel you like. I know the Cruiser back spacing is not really common.
What are you planning on using your Cruiser for. Daily Driver, Rock Crawler. Post up some pics of your new Cruiser.
