White cruisers rule, obviously. Nice pix!Follow along with the video below to see how to install our site as a web app on your home screen.
White cruisers rule, obviously. Nice pix!Beowulf said:acf,
>> because it will throw "the computer" off <<
Technically he is correct. There are a lot of computers in your vehicle. There is the computer that controls the shifting of the tranny, the main ECU that controls emissions, the computer that tells the SRS how fast you're going, and more.
The easiest solution is to acquire the speed sensor gear that Christo sells. When running 33" tyres (285/75 or 305/70) it will put your speedo and odo very close to actual and it's an easy install and relatively inexpensive. The tranny will shift at the proper speeds and all sensors and ECU's will be accurate.
That being said, it's not a big deal and I seriously doubt there would be any problem without the VSS gear change.
-B-
acf said:Thanks, Beowulf, called the dealer for grins and their service dept. told me flat out not to do it.![]()
Crusin said:Brent,
That looks really nice. Is that stock suspension? I just ordered mine today ( Revo 285s) but its in back order maybe a week or two. Can't wait on mine after seeing the before and after pics.![]()
That's what I was afraid of. The speedo correction module Christo sells correct all that, right?Beowulf said:>> Curious if my mileage on odometer is also affected???? <<
Yes, same percentage as the speedometer. This was one of the main reasons for adding the correction gear. If I ever sell it (no plans) I can sign the mileage disclosure certificate with no reservations.
-B-
any longer.Beowulf said:>> I wouldn't fit her into the garage <<
Easy, raise the roof.
-B-
cruiserdan said:Air down......![]()
(He wants a set of deflators too but can't figure out when he'll need them)
. It cuts into the harness behind the clove box. It is a little tight back there but it can be done with good results. I basically tapped into ground and 12v on the plug by soldering the Truespeed harness to it. I personally don't like Butt connectors especially when tapping into something that is connected to some sort of Computer module. If thge connector loosens up and some spiking might be a problem. The Video signal from the speed sensor gets cut in half and then spliced to the two lines from the modulator. Using the supplied velcro I stuck my unit on top of the heater core. There is just enough room up there and I haven't had any issues of it coming loose. I did make a jumper incase the module let go I could get my speedo back, wrong but at least something to look at and CC would work.
My boss is now on this forum now
out of those
Yankees).
to help another cruiser owner do this. I don't own a soldering gun. I'm good with splicing, but all I've ever used is the butt connectors.
