tires and rims
did the searches and still confused, seems theres some info conflicting and its probably due to everyones different upgrade etc. will steel american racing rims with a 4 inch backspacing fit a 1971 with origional drum brakes all around. and will a 33 x 9 inch tire fit with origional suspension that is sagged. i just want to get this thing rolling and registered and get a 2 inch lift come spring. the way ive read the past threads is that the 3.5 inch backspacing is only needed for trucks with disks. 15 x 7 rim size
4in backspace may physically fit - but will be close to rubbing on the tie rod balljoint. A bigger problem will be rubbing the inside of the rear guards with any articulation. The biggest problem will be finding the truck lying on it's side as soon as you get on any side-slope. It's a reasonably narrow wheel track to start with, and a 4in backspace with skinny tyres will make it VERY tippy....
look into 2.5 or 2 inch backspacing, looks very good and no troubles rubbing etc, looks better imho
well i found bigger rims with the right backspacing, but they will need wider tires. was really hoping for the narrower tires. i have no experience with off roading with a landcruiser and dont know how well it will handle in heavey maine mud, the truck i drive now , dodge dak convertible, gets mud sucked, frustrating when you cant get the wheels to turn in 4x low, it has no real torque power. hope this truck handles the mud better. im sure it will.
