Tire Question
Eastern PA.
I'm looking for a tall tire (34" or bigger) with out going to a 12.5" width tire.
Is there anything like that out there? I looked at BF Goodrich and they jump from 33 x 10.5 to 35 x 12.5. I have 33 x 12.5 on 10" rims now and I'm trying to get a tall tire that fits under my front fender.
Can I put a 12.5 on an 8" rim? That might bring it in far enough so my fender covers the tread... as long as it doesn't rub the springs when I turn the wheel.
Kevin
You can put a 12.50 on an 8" wheel....but it will not change the tire much...only put more pressure on the bead seat area, and help keep the tire on a 15" wheel at lower pressures.
Options increase if you go with a 17" wheel....
Hi All:
Look into some of the metric tire sizes that use a 16 inch rim; many of them are tall and narrow.
InterCo's Super Swamper tire line also has some tall and narrow models, though usually only available as a bias-ply.
Good luck!
Alan
Seattle
that might be a little tricky to do, typicaly the taller the wider they get, not always but usually. i have 12.5 on 8 inch rims they didnt stickout until i changed the backspacing on my wheels, you should be alright
Well I found black spoke wheels in 15" but if I go to 16" then the back spacing goes to 4.5 which may or maynot work but will push the tire further out from under the fender.
17s would be nice but I'm kidding myself if I don't go for the 22s... And ya gots ta have Spinners :)
Kevin
Hi All:
"Toyo" I believe you are mistaken - 4.5 inch backspacing is too deep for a Land Cruiser; stock wheels have 3.5 inch B.S. More backspacing ("deeper") brings the tire in closer to the body tub.
Regards,
Alan
Seattle
From what I understand the offset on a 16" wheel can be larger that the 3.5 offset on needed on a 15" wheel.
And what I said about 4.5 offset doesn't make any sense anyway. 4.5 offset would bring the wheels closer together.
Kevin
funny poser, readings for dummies
the smaller the number the further from the truck your wheels will be. i like 2 inch backspcing.
I'm running size Q78-15 TSLs and they are about as close to your target size as any tire I know of.
You should just go to 37's to begin with, i wish I had.
