tire question
Morro Bay CA
hi ive got a 72 fj40 with some 31-10.50-15s now but im gonna up to some 33s becasue i now have the room with my upgraded shackles and i was wondering how i could stop scrapping the damn chassi when im flexing my cruiser i dont wanna do anything major but are there any options besides to cut the living hella out it and put longer axles? :)
huh, there are all sorts of options, i ran 33 for years and never had to cut or get longer axles? you got pics?
So if I understand this right, you currently have 31s that rub on stock suspension, but you're adding extended shackles and think you're going to fit 33s without cutting?
and are you scraping the chassis on rock or your tires? or are your tires scraping the tub?
im rubbing on my chassis and i can now fit 33s since i upgraded to theres shacles :)
BEFORE
AFTER
in the 2nd pic you can see the rubbing on the chassis
wait now that i think about it there isnt really a solution just less wide tires like some 9.50s becasue no matter what when i flex that crazy its it will awaways rub on that section unless i get spacers or something correct then cut and put buchwakers on right?
becasue if you see its not hitting the chassis its rubbing on the body tub sidewalls i think :confused:
You rub there because when the axle articulates, the motion is in an arc and brings the tires into line with the inside of the wheel well. The only way to not rub there is to bring the tire out away from the spot it hits. That could be accomplished by spacers, but that is not the route I would go.
Increasing tire size by 2 inches will exaggerate the rubbing by 1", so if the problem is corrected at a 31" tire, it may rear its ugly head again at a 33" tire.
Personally, I just don't care about my tire rubbing there. I have 36" tires with stock axles, and my "rub" mark is much larger than yours, but it has never done any damage to the metal or my tire so I haven't done anything about it.
If you are seriously worried about the rubbing, look into a wheel with a different backspacing or a skinny tire. Honestly though, I don't think you have anything to worry about at all. Get the 33's and enjoy. :grinpimp:
soa then you wont have to worry about with 33's youll be fine, before i did soa i rub too wasnt worried about, even though it sounds like somethings getting ripped to shreds back there.
