tire psi
Check your sidewall for max pressure and load.
And then forget all about that unless you want to calculate how much weight is at each wheel and divide to figure out how much pressure BFG recommends for that load.
On an empty hardtop 40, I'd start around 25 with a 33x12.50 and go from there. Also, making chalk marks across the tread and checking for tire contact can help get you in the correct operating range for your tires. My 33x12.50 radials are on 8" rims and I run them on the street at 22psi - and that's a little stiff, but with a welded rear end, they chirp a LOT at lower pressures. I'd run 18-19 otherwise.
When I had TA's on my truck (94 Chevy 4x4 6500lbs G.V.W. 265 75R 16) ) I ran the presure a little on the high side (60psi) it made the sidewalls stand a little taller. Rougher riding though.
My BFG both 33x 10.5 AT and MT I run on my 40 around 30lbs, or 28lbs. Anymore and they beat the krap out of you. I noticed a difference when I put the Rancho RS9000X shocks on!
later
Ryan
I also run my 33x9.5 Goodyear MT/R at 20-30. You'll have a little sidewall bulge.
