I'm reading through all the threads I can find on front axle services, front axle problems, knuckles, spindles, wheel bearings, you name it I'm reading up on it. I've had my rig for about 2 and 1/2 months now. The front axle needs attention.
Is it easy, if you're a qualified mechanic, to assess the front axle needs? What I'm asking is, can someone with a lot of car mechanic knowledge look at the rig and see if it only needs seals or needs new knuckles or spindles or whatever?
I ask because I don't want to be riding "18 miles to work" (like I read in one post) and have a bearing or something else go bad on me. So put simply, can my front axle be assessed and then what needs to be replaced be replaced or is there stuff that won't have evident play or wear and hence just replacing everything (which I know is crazy $$$$) is the most efficient preventative approach to the front axle?????
errrr and I thought I was almost ready for the build to begin
Is it easy, if you're a qualified mechanic, to assess the front axle needs? What I'm asking is, can someone with a lot of car mechanic knowledge look at the rig and see if it only needs seals or needs new knuckles or spindles or whatever? I ask because I don't want to be riding "18 miles to work" (like I read in one post) and have a bearing or something else go bad on me. So put simply, can my front axle be assessed and then what needs to be replaced be replaced or is there stuff that won't have evident play or wear and hence just replacing everything (which I know is crazy $$$$) is the most efficient preventative approach to the front axle?????
