Hello friends its almost a year now i'm struggling setting my timing of my fj45.sometimes when i do it,it backfires like a shortgun.in other words i want to get it started engine ruñning so it doesnt want to do so.sometimes it will start but in a very deep low sound where by even i turn my distributer to get a better sound it doesnt change at all.
Also with the spark.my spark is very weak when by when i check spark at the points it backfires the spark to the coil and you could clearly see it at the coil positive wire its blue.but at the plugs it comes out red and weak.i put my piston #1 at TDC and on the dot mark at flywheel but it fails to start.it will have that sound that its about to fire then nothing happens.i'm just tired of this thing.what might be the problem or cause of this and what should i look for which i might missing out.
Thank you
Thank you
