Timing
A very quick and easy test to see if the dizzy is 180 out. Swap the plug wires.
Pull plug wire 1 from spark plug and put on 6 plug. Put 6 on number 1 plug. 5 to 2, 4 to 3 ect.
I ran one 2 years 180 out this way.
Thanks will get into that
So #1 is after 4 not in between 3 and 4.
That is correct. This is what your distributor cap should look like:
1994512
And you just match the numbers up with the correct cylinder starting at the front of the motor (the fan side)
If you follow the distributor in the clockwise direction, you will get the firing order: 1-5-3-6-2-4
Hope this helps.
Hope this helps.
This is the thing which gives me hard time
1994516
