See @HAAANK 's comment in the following thread that COULD be related.....
93 LAnd Cruiser hesitation
WTH is the NSS barrel connectorSee @HAAANK 's comment in the following thread that COULD be related.....
Great info but his problem began with startup following HG replacement and is not intermittent.Neutral Safety Switch under the center console under the shifter handle. Have to remove the center console cover. The barrel connector is the electrical plug-in.
Yes all by itself after the click and increased idle.. I know it seems pretty straight forward but I am having a heck of a time..I’m still learning about these rigs myself, that’s why I participate.
The timing advanced to 15* with diagnostic port jumper in place and at idle?
Thanks for the help guys.. I messed around with it a bit on my lunch break and have a a little more info.. A quick look at all the vacuum lines and everything looks good.. I checked the TVV lines to be sure they were going to the proper ports and they are. EGR ports are all plugged up as well as the pair.. I didn't use teflon tape when installing the sensors.. Just some locktite as per the FSM. I checked timing again with the pins jumped and it was hitting 6-7 BTDC like I had set it. I then heard a relay or something click and the idle increased then the timing went back up to 15.. So it sounds like the ECM is triggering something to advance timing. I did double check the timing with another old ass timing gun and it was showing the same.. So I am pretty sure the gun is functioning properly.. Any idea what the ECM is triggering to increase the timing? It is pretty easily duplicated.. If you start the car with pins jumped and cel flashing and hurry up and check timing it will be around 6-7 degrees. Then that click and timing advance. This all happens within about 30 seconds of starting it up. I tried getting a video but you can't hear the relay click and idle increase on the video.. The engine noise is just to loud.
No AC the vents were on heat floor and main vents.. Never on defrost.. Which I am thinking automatically turns on the AC.. I'll try again with the blower totally off..Is your AC on? It will idle up and increase timing when the AC kicks on. Turn OFF the AC, set the interior vent settings to floor and turn down the fan.
I'll have to check it does have a button but I am pretty sure it is not pressed in.. Oh man if it is and that was the cause of all this I am gonna feel really dumb ;>)Do you have a separate AC button to turn it on? Was it pressed?
Haha! Never feel dumb because obviously it takes a group of us to figure these things out thread after thread.I'll have to check it does have a button but I am pretty sure it is not pressed in.. Oh man if it is and that was the cause of all this I am gonna feel really dumb ;>)
Thanks for the ideas.. I did install the fuel line washers properly along with a new filter and all lines are looking good.. No kinks..I don't think the "click" you hear is anything related to the IAC. That only controls idle speed and would not cause poor performance or slow acceleration. I would monitor voltage on the FP terminal in the diagnostic connector to see if the click corresponds to a change in voltage. I'm thinking there may be a problem with the fuel pump relay, resistor, pump or the fuel filter. Maybe the fuel lines were not installed with the proper copper washers on the banjo bolts, a kinked line etc.
Yeah my manual temp gauge says it is 190 deg.. So I'd call that normal operating temps.I always thought that tune up adjustments were supposed to be done with an engine at normal operating temperature. If it is really cold out, is the rig getting up to that temp?
