timing gear install
I have a 1986 FJ60 2F engine. Forgive me for posting here as well as the 60s board, but the situation also fits the 2F in the FJ40. I am trying to resolve an oil leak around the timing cover which we think was caused by the oiler being screwed into the timing plate too far. To be safe, I would like to take the timing plate off and re-gasket. That involves removing the timing gear. I have been advised that the timing gear on the cam is pressed on (plus a C-clip). I think I can pull it off with the proper puller, but HOW DO I GET IT BACK ON? I have been advised that I cannot hit it because that will cause the camshaft to go backwards and knock out the oil plug in the back of the engine, making matters worse.
Please, please, please don't tell be I need to pull the cam.....
Heat is your friend!
I've done exactly what you are planning a couple times with good success. Replacing the timing plate gasket really helps to stop that pesky leak at the front. I've pulled the timing gears with a gear puller after lubricating with PB blaster for good measure. Go slow and be wary of applying too much pressure at one time or you run the risk of chipping a tooth. Mine came off relatively easy on both occasions. Clean and dry all of the surfaces really well; especially the threads of the bolt holes before apply the new gaskets and sealer. When you are ready to replace the gears place them in an oven at 250* for 15 - 20 minutes. Don't heat with a torch as too much direct heat can alter the surface hardness of the gear. After heating, it should slip over the camshaft easily. A slight tap with a soft mallet won't hurt a thing. Don't forget to replace the keyway and the c-clip.
HW,
I had the same issue - machine shop bottomed out the squirter on the block - BITCH!
I just tore the valvetrain off the top and pulled cam and timing gear together...
Hey, don't forget to put sealant on the two bolts that go into the front main cap!
I have had TWO of the last 2F's come back this way from the machine shop... the last one is sitting in the shop waiting to get yanked back apart. The machine shop has been good about covering the warranty, but it is so discouraging to pull the motor back apart just after finishing. We left the cam in place on the last one, and used a "custom" puller to take the cam gear off the shaft... worked great, but I ordered a couple of the snap rings because I didn't like the idea of re-using the same one.
fcgadget said:
do you have a picture of your "custom puller"? I need to do this and don't really want to pull the cam.
And when you put the gear back on did you do the oven heat method, or.....?
Our "custom" tool is a two jaw puller... we took a grinder to the end of the jaw to give it a sharp hold... we put it inside the holes of the cam gear, and a second guy holds the teeth in place... really a PITA.
We preheated them in an oven... just like doing a R&P :D
Hey guys, I have a stupid question. In the pictures earlier in this thread, what is the "hole" that has something red in it? I have a 1F engine and oil appears to be leaking from whatever that is. Is that the cam oiler? I've looked everywhere on this forum and this is the only thing close I could find. Thanks for the help.
This is from EFJAY's post earlier:
I think that is an oil gallery and should have a core/welch plug in there. I believe Toyota part number is 90330-24013.
Check here: http://www.partsbase.org/toyota/lan...80-eu-1-cylinder-block-2/#p-toyota-9025315005
1984 FJ40 LX, 12HT Turbo diesel
Efjay, Today at 2:41 AM Report
#2 Like − Quote Reply
Working on a reassembly myself, and we were just talking about doing the whole job with a cressent wrench and screwdrivers, in the desert, in a sandstorm, and it still runs for 10 years!
