Tie rod ends (grease boots)
IIRC, Engery Suspension makes some universal urethane covers. Measure yours and check out their catalog. Let us know what you come up with.
I don't think that anyone sells replacements and that the poly ones are your only option.
I did not check too hard but found none available in a search recently...do keep us posted it would be very nice to be able to replace that f-ing thing...mine's glued and I'm sure it'll be fine, but still would be nice if I could replace it.
Thanks for the info guys. I'll keep looking, and let you know what I find. I just figured since there are so many FJ guys on here, that surly somebody would have replaced such a common part.
There was a thread where a dude had a bunch of them I found by searching...called his shop...no more. But I get where you're coming from it seems reasonable that you'd be able to purchase it separately.
Engery Suspension carries a "universal" boot which comes in both round and octagon style. Based on the measurements of our tie rod ends, the following ES parts should fit:
Round Octagon
9.13119 9.13120
These usually two per card
Round Octagon
9.13119 9.13120
One of my boots was recently damaged so I'm thinking of giving these a try. Anyone try one yet?
I have this needle that connects to the grease gun. Looks like a surgical needle on steroids. The way supposed to work is to push the needle into the boot and squirt grease. I'll give it a try and see what happens, after all I have nothing to loose.:D
Round Octagon
9.13119 9.13120
I ordered the round 9.13119 and the DO NOT fit. WAY TOO BIG. I measured the base diameter of my TRE to be 1.288" and these boots are 1.615". My TRE pin diameter is 0.585" and these boots are 0.640". I checked the Energy Suspension catalog and couldn't find anything close to these measurements.
I found what appears to be the original rubber boot from Cruiser Outfitters Part# TG130089-1-KITT. But they are $9.25 each!
