Thoughts on this 80?
Navarre FL
I'm about to pull the trigger on this vehicle. I'll be using it as a DD with the occasional offroad trip at the hunting lease. The mileage is low considering most I see for sale have 200k plus, however the HG has not been replaced. The seller has agreed to a price below what is advertised, however I'll be buying it sight unseen. The autocheck is clear with only three owners, mainly a FL vehicle.
Do you all see any GLARING issues? Obviously the paint will need to be fixed and new leather may need to be installed.
IMO....the heater control valve looks to be due for a replacement at any moment. Hopefully you're in your driveway when it decides to crack. Also, the air intake hose may be working but it is not what probably should be there. Looks to be homemade. The valve cover looks too clean to me. The water droplets on the distributor cap and the air filter box suggests he degreased everything before taking pics. That could simply mean you'll need to replace valve cover gasket, which is not uncommon.
Seller says he had the front main seal, timing cover, dizzy, oil pump and valve cover gaskets recently replaced but I haven't seen any receipts. I had the same thoughts regarding the air intake from the snorkel, is that what you're referring to BullElk?
Well, it probably does leak a little oil. The only ones that don't have leaks had all the seals replaced. But that isn't the end of the world.
Truck looks clean. The HG isn't a preventative maintenance item. If I had to buy a 1FZ-FE I'd rather have one that hasn't been replaced than one that has and you don't know what they did, whether they checked the head, machined it, etc.
Buy it and plan on a couple of grand in maintenance to get it up to speed. If you don't have to spend it its money saved.
The black flex pipe between the air cleaner and throttle body intake looks to be from Home Depot. Its a landscaping pipe used to drain water from your gutters and downspouts away form your foundation. :eek:
Or it could be a RV sewer drain pipe? Its not stock for sure.
i would replace the radiator cap and intake tube right away. Intake tube is the black plastic one going from the large black air box to the throttle body.
I like to see new OEM parts and maintenance done. But most people only replace parts when they fail or there is a problem. So if someone has for example a new radiator in place. Ask yourself why. Did it crack and did they overheat the motor? I dont trust other peoples work, except a few LC specific shops and some of the Mud members here. I would rather have a good running motor that has a original HG. That way when i do it myself i know it is done right with all OEM parts and a full rebuild of the head by a COMPETENT machine shop. I am probable going to do my HG in the next year or so. I will have a stack of OEM receipts and a receipt from the machine shop that is recommended from several venders on here that does their cylinder heads. I would expect to see the same documentation on a truck i was buying before i was happy.
Truck looks OK to me but there are other people here with much better eyes than me. Buying with out a test drive is a real gamble IMO. I dont know if i could do it.
Let me understand this:
You want to use this as a DD?
You want an evaluation of a motor by visual inspection?
You Negotiated a price before you know condition?
Call me a Pessimist but this has Danger, Danger, Danger written all over it.
Are you sending the money Western Union or they delivering this truck to you for free?
Behave:flipoff2:
It has a Snorkel and Running Boards.....Deep Mall Crossings ???
Drawers do look good.
Well when you put it like that...
I'm away from home 4-6 months a year, sitting around and waiting for the Unicorn LC is not going to happen. I've already let two slip away from me trying to negotiate a price.
The guy has 100% eBay feedback even if it's not for vehicle sales. This one also happens to have one of the better price/mileage ratios I've seen recently. I don't need it as a DD immediately, but within the next 2 months.
It sold for $8,500 which was a fair price.
I found another forum member that is going to visually inspect the LC. Thanks to all of you for your input!
