Mine do it too, all the LC200s I have had do the same thing. You have about 4-6 gal left depending on how you typically fill your vehicle. Ie if you top off like I do and squeeze an extra gal or two in the tank then it would be perceivably that I had only 4 gal left when I fill up. If you quit at the first click, you might think you had 6 gal left....
This great point from a related thread made me wonder: Does anyone know - as the result of an actual (accidental?) "ran out of gas test" - how many gallons the fuel tank and filler neck can hold?
I routinely run up to 40 miles on the highway after the light comes on. If I know my average fuel economy, the number of miles I've driven since last fill up, and I assume I have at least 24.6 gallons or so of useable fuel, then I can easily calculate how many miles I can go after the light comes on. Like many of you, I have found that I can put in about 19.5 gallons after the light comes on if I allow the pump nozzle to shut off automatically and I stop there.
But! Do I have to fill the tank up to the top of the neck to get 24.6 gallons? I am betting that is not how the tank is designed. I'm betting we get about 24.6 gallons when the average nozzle shuts off.
I just returned from our twice yearly 28 hour trek up to PA and back, and I twice filled over two more gallons after the nozzle shut off. One time I got in 2.5 extra gallons, and the other I got in 2.7 gallons (and spilled a bit on the paint). You have to get a nozzle that allows you to slowly add gas; not all of them allow fine control of the pump speed.
Yesterday we had a strong headwind and I had a large bag on the roof, five adults and a large dog, guns, ammo, and suitcases - a full load. I could only average about 17.2 mpg. This might seem good, but two hours of that trip was at ~45 mph or less in snow and freezing rain. Anyway, after topping off the tank (2.5 gallons past auto-shut off) I drove about 387 miles, which was about 50 miles past when the low fuel light came on. I again filled the tank to the top of the neck with 22.7 gallons.
Here's what I wonder: If the truck holds 24.6 gallons at the top of the filler neck, that means yesterday I had only two gallons remaining...I don't know how much of that amount is useable, but certainly not more than a gallon if that. That's cutting it way too close.
My hypothesis: If the truck holds 27 gallons at the top of the filler neck, that could mean well over 100 miles of additional range after the low fuel light comes on, conservatively assuming 19.5 gallons have been burned at 18.5 average mpg and assuming we don't want to/can't use the last 1.5 gallons in the tank.
27-1.5-19.5=6 gallons available after light comes on; 6g*18.5mpg=111 miles! Or so...depending on how much risk you are willing to accept.
Is there a downside to filling up within a couple inches of the gas cap?
100 miles extra range at 75 mph! That's significant! Your thoughts?
