Thompson Coupling CV joint
Thats pretty neat.
I never knew a universal joint spun different speeds either. and yea, I wonder how long till we see this affordably priced for autos maybe even as upgrades for stronger parts.
The only problem is that its only operates at a maximum of a 15 degree angle. The guys running high articulation rigs would need more than that.
the impression i got from the video was that 15 degrees was the maximum for a traditional cv joint. he was just comparing the 2 products at the same angle to show the difference in operation.
ok so i did a bit more reading, they are rated to 15 degrees at 2500rpm which is a lot faster than an automotive prop-shaft is going to turn. at slower speeds it seems they can handle angles of 30 degrees maybe a bit more, which is a lot more than a standard cv.
heres their website Thompson Couplings Limited
Huh? 6000rpm small block with 1:1 gearing can turn the prop shaft at, um, let me calculate...about 6000rpm; more with overdrive. Maybe not in a wheeler, but that's under 100mph with smallish tires.
6000 rpm with 1:1 gearing, 4.11 diffs and 31's is 134mph or 215kph! fastest i have pushed my cruiser is 145kph (90mph).
6000 rpm with 0.85:1 which is a h55f 5th gear would put you at 158mph. i dont know any high articulation vehicles that travel at these speeds or that run 31s
upgrade to 38" tires and you are pushing the 200mph mark.
now 2500rpm with 0.85:1 with 4.11's and 38's comes in at 80mph, or 65mph with 31's. i doubt you would be holding up traffic when driving to the trailhead.
OK, the RPM may not be an issue.. but 2000nm is only 1475lb-ft. a 1310 joint is rated for 1,600lb-ft continuous, and we all know they don't work well for a rear shaft. Plus, the small one (rated for only 369lb-ft) weighs 11kg - that's 24 lbs for the little one.
Good find though, we gotta keep looking in other areas to find new products!
Might not be perfect yet but it is a relatively new product, some of the ones on their site were rated for higher loads but of course with added weight and size. I guess if they had enough interest expressed in offroad applications, whether they be recreational or military/industrial they might put some focus on research for these areas.
Another thought is what materials are they using for different applications? Just like aftermarket axles vs stockers.
6000 rpm with 1:1 gearing, 4.11 diffs and 31's is 134mph ... fastest i have pushed my cruiser is 145kph (90mph).
So 90mph = 4000rpm. I repeat my, "Huh?"
