This is probably like my 5th post on here, so tia for all the
Anyway, I think I finally have my cruiser able to start after replacing a bunch of corroded/mudfilled electrical bits. It's taken forever,
but I'm slow and lazy.
The thing hasn't run since I pulled it in the garage almost exactly one year ago. It ran fine when it came it, it was just having issues
starting because of all the electrical shat.
What stuff should I do or check before attempting to start it? I am assuming it actually will start when I try it this time.
The oil was pretty fresh when I pulled it in and I will change it as soon as I verify it's going to run so as long as it's full it should be ok?
I didn't put anything in the gas as I didn't think it would be out of commission this long. Draining probably won't be necessary right?
Should I add anything now, or just dilute it with fresh as soon as I've burned a little of this off?
Anything else I might want to do or check? Drop some oil down the plug holes? Starter fluid in the carb?
TIA for any help or suggestions
cruiser pron for the hell of it
