Thermostat Change
I am in a budget and unemployed for the time being but if I get a oem radiator cap and oem thermostat, that would fix my heater problems? I just don't want to spend any more money and find out that this won't solve my issues. I have other problems with my car that needs addressing as well.
Gotcha, budget issues here too. But like I said, check the heater valve operation.
And, did you have heat before?
I just bought this 91 fj80 w/ 245k miles. No heat before and previous owner said top of radiator was leaking so I did replace it this week. After driving about 20 min or so then the gauge goes to the middle. It's been about 15-20 degrees outside and I have it parked outside. There was no heat before and no heat now. I'll see if Theres heat in the back when I turn it on. So do you guys think that I should just swap out the thermostat with an oem one after reading about some of my posts here or what? I also was looking at other threads about the heater valve and need to check it out when I get some time next week
If the gauge goes to the middle, your heater valve is stuck, or the heater core is plugged with crusties. I hope it's the valve, its easier to fix than the core.
My heater gauge stays under half all the time.
meister88
On a 3fe thermostat, there are two gaskets. When the thermostat housing is open, you drop the thermostat into the lower half. Then you put the gasket on that seals the two halves of the housing. Then you put the round gasket on top of the thermostat. Then you put the top half of the housing on and bolt it closed.
If you don't get the round gasket on top of the thermostat, then the coolant bypasses the thermostat and never heats up.
Here is a picture I stole from LC8PILOT's 3fe refresh thread. Hopefully this makes what I am typing make sense…
Also if your aftermarket thermostat is not exactly the same height as the OEM it also will not seal correctly internally.
meister88
Ill have to check out the thermostat again, I am pretty sure that I did everything right in accordance to what you are saying. The OEM thermostat was not in the car. The previous owner had another aftermarket one in there.
Just a side note to everyone that has been paying attention to my ramblings lol. The heater valve is properly connected but still havent checked if it needs to be replaced or not. I am pretty sure that it does. Also the heater in the back is only producing luke warm air just like the front of the car. After driving the vehicle for 20-30 min, the gauge goes to the middle or slightly under and there is no heat at all.
Comments:
A. Thermostat needs to be replaced with an OEM one???
B. Heater core is clogged ? or Thermostat is stuck to the open mode?
C. Heater valve needs to be replaced???
I am stuck and don't know what to do because its extremely cold and I only have about $50 in my name. Autozone has a heater valve unit for $35 and wasn't sure what my next step would be.
meister88
The aftermarket thermostat came with an O-ring gasket and I also purchased an additional gasket that goes on the thermostat housing.
I am stuck and don't know what to do because its extremely cold ...
What about the old 'stick a piece of cardboard that covers a good part of the radiator' thing? It's :hillbilly:, but worked fine on those 0°F days when my Blazer was living in Nebraska... At least as a temporary solution until the $50-situation improves a bit?
In your case you should start with a new thermostat.
Note that this is another car and not the OP of the thread. Would be slightly less confusing if you opened a new thread, or waited til the OP (original poster) has fixed his car lol
/end jack/
/end jack/
Whatever dude, just trying to be helpful as always...
Post # 19 is where this thread went off the rails FYI, maybe you need to read more comprehensively "86tuning". ;)
Replace the thrermostat and call it a day...
And FWIW,
Autozone thermostat = 19.99
Autozone Thermostat gasket = 15.99
Total = 35.98
Toyota OEM Thermostat = 26.00
Toyota OEM gasket = 8.00
Total = $34
The OEM Thermostat is cheaper than Autozone and I usually find that Autozone is the cheapest out of all the chain autoparts stores in my area.
I just called around and ordered a thermostat and gasket about 10 minutes ago.
Replace the thrermostat and call it a day... And FWIW, Autozone thermostat = 19.99 Autozone Thermostat gasket = 15.99 Total = 35.98 Toyota OEM Thermostat = 26.00 Toyota OEM gasket = 8.00 Total = $34 The OEM Thermostat is cheaper than Autozone and I usually find that Autozone is the cheapest out of all the chain autoparts stores in my area. I just called around and ordered a thermostat and gasket about 10 minutes ago.
Boy, that's pretty cheap for OEM. Is it from one of the MUDs vender?
I bought one from Beno back in August for my 92 3fe. The thermostat was $33.26.
Sent from my iPhone using IH8MUD
