Thermostat Change
Western, SD
Probably a stupid question but could I get away with changing my thermostat without draining the whole system? There are below zero temps around here right now. I was planning on doing a total cooling system overhaul sometime soon but not quite yet. I want to throw in the thermostat quick and top the coolant off.
Just did mine yester day as the thermostat got stuck open so no heat. I just put a bucket underneath caught it then ran it back through a paint strainer to get any dirt out.
Not trying to hi jack the thread but I replaced my radiator with a Silla Radiator and upper and lower hoses and also replaced the thermostat with O ring and gasket but the car is getting no heat what so ever. Also the temperature gauge takes about 30-45 min of driving to get to the middle. It is about 30 degrees outside now. Did I do something wrong?
I should say that I have a 91, thanks for any info that would be helpful for me to remedy this problem. I should check if the rear seats get heat as well
I used a Stant thermostat and it died within a few months, I bought OEM and been perfect for a few years. Go OEM and new rad cap also. Get both OEM and use distilled water not hose water.
I just bought an autozone radiator cap and autozone thermostat. No problems but there is no heat what so ever in my car...
Check the heater valve, should be center mounted on the firewall. Could be the actuator cable is disconnected or the valve is busted.
Ok, so firstly you can replace the thermostat without draining too much coolant on the "3fe" all you need to drain is down to the bottom of the inlet hose and your good to go, then just dive into the outlet housing. Make sure to replace both gaskets on the thermostat. I live in the southwest and just put an OEM 180 degree thermostat in my 1991 and couldn't be happier, what area of the country do you live in?
:wrench:
Oh south dakota you definitely want a 190 thermo.
Yes. Should warm up in <5 minutes of driving.
:rolleyes:
Toss that junk and do it right.
Y
Yeh I agree, the OEM is way better made and temperature accurate for our rigs. So is the cap. It may be more but in the long run its so worth it.
I am in a budget and unemployed for the time being but if I get a oem radiator cap and oem thermostat, that would fix my heater problems? I just don't want to spend any more money and find out that this won't solve my issues. I have other problems with my car that needs addressing as well.
Lol. No problems other than no heat?
Does the temperature gauge sit in the middle or at the bottom?
If it sits in the middle then check the heater control water valve on the firewall.
If it sits on the bottom, a defective thermostat is the most likely problem.
Genuine thermostat is $10 more than aftermarket. And that's only a couple gallons of gas difference in price. Doing it twice, throwing out the aftermarket parts costs more in time and labour.
