Amazon product ASIN B07CT821B1
You can also install one of these between turbo and filter housing and you can check highest vacuum any time
Just fitted to my diesel 1HDFTE. Went into the red zone straight away. Changed the air filter and at 50% of the yellow zone. Are there different models for different engines and modifications. I am at 35+ psi with my GTurbo red wheel and other tweaks. Hungry for air.This doo-dad suggests my intake restriction is way too high even for a quick rip around the block! 1FZ airbox lid mod is it the works.
I have one on mine, but have not had the older style one on to compare. They do make a larger one again for newer cars called safari airmax, but don't make them for the 80. Could you email them and ask for a CFM comparison between the 2?Has anyone tried the new safari snorkels? Apparently the SS82HF now has a larger body and larger snorkel head, which apparently should flow a little better... It still has the same outlet size, but may flow better due to the fatter body resulting in a less tight angle...
@IanB Were you able to get around to doing the 1FZ lid?
Very nicely done, can I ask how you’re planning on holding the airbox together? Is it just going to be clips around the outside or...? Would also love to see some more pics of that build if possible...
Haha!
