- Thread starter
- #261
Drives well indeed.
That worn down pin with spring on the steering column side is a $6 part from Toyota. Have Beno send ya one and you can pull out the washers and be good for another 10-20 years
Are your rear fenders cut behind the rear wheel? can you post some pics of the area and how the welding was done to close the hole?
If your panel (s) are that far gone I would just jump ahead to total replacement of the area. There are enough 60 series out there in parts yards that you can have them cut a good section for you out of a parts rig. Cut yours to match theirs and weld it back in. There may evven be replacement panels available out there, I've never looked into it.
There are replacement panels from at least 2 sources that I am aware of.
I've thought about trying to find a donor part, but if I can't find it locally, then it may not be cost effective.
