The Life & Times of Shasta (86 FJ60 conversion to HJ60)
You're not supposed to cut the leads!! Also, did you install a ground on the motor for the tiny tach through its harness?
EDIT: nevermind. I'll show you on saturday.
Yes. Installed ground. There was no cutting of the lead that runs to the engine for the transducer or ground. It's just run thru the lamp hole in the gauge box
I don't remember these two wires coming from TinyTach without connectors. They all had those small circular connectors, no?
EDIT: Wait, those were probably power. Nevermind :)
Little grey is power and ground. I actually read the direction first this time. Nice people at Tiny Tach said if I'm getting back light (which I was) and no numbers on the lcd then the head is a bad unit.
Also the space on either side of the transducer is correct per TT
Starting soon.
A little time with a flat file will straighten the sides out on your cut out
2015-02-14-17-27-47-jpg.1033947
Before.
Prepped for surgery
Yes. Same lift height as before.
More progress
Front done.
Finished around 6
Sitting just about the same height pre-break. Test drive today.
Sun and new legs. Drives wonderfully. So glad I went with new.
Thanks to @mtweller @GLTHFJ60 the hard work.
So that's why you wren't doing any work, you were taking pics and surfing the forum :flipoff2:
She drives well?
