Build The honey badger build
why not just deal with the exhaust yourself?
bends and parts are cheap and it's not like you can't weld 😂
We will see . I guess i can run it without the 02 hooked up so i can get in on the trailer and in the shop .
What a crap week 🤦🏻‍♂️. We had a crazy snow storm this week. And that screwed up
Delivery’s 🤬. Yesterday I had part of my order from Advance Adapter show up . But not what I was really wanting 😞. Have to wait till Monday for that 🤦🏻‍♂️. Last night I got motivated again so I decided to mount the t case adapter to the trans . Then I pulled the engine and married the trans to it 🤩. And then I installed back in for its final time 🤗. . Today I will work on hooking up the trans shifter . And I will
Probably fire it up 🤩.
First I made a quick templet just to make sure
With my confidence up I crawled under and benched that heavy pig up And No the gold bar is not part of it. That just to hold the trans kinda in place for now . I just need to notch that floor rib a little but it’s up and in 🤩. Now I will have a 25 inch rear driveline. Actually longer than I had before and the front is 38 inch. My old front fits . I will just have a new real yoke put on and a real u joint . There is tons of room . At this point I am very happy . I moved my engine back 3 inches fixing that nagging issue and with the shorter trans and t case I now actually have a longer rear driveline 🤩. And it is now centered . I got some mounts from Ruffstuff to make a crossmember
So question for you guys . As you can see the transfercase adapter has a place to bolt to . The gold bar is my old Crossmember and its just holding the trans up right now .. Do you think i could make a plate and solid mount the trans to the plate and then have a Tube welded to that and have bushings on the ends if that makes sense ? I have a bushing coming but its about 1 1/2 thick
Like this
Although I put bushings at the frame and under my transmission, I don’t think that I need both.
Mike do you have the t case mounted as well i cant remember if you got one of the tmr rear mounts I have heard they are not good to use ?
Yes, I put a transfer case mount on mine. AA strongly advised against it but mine seemed to need the extra support since it is longer. You may not need it.
You have the 4 speed so yes that is a lot of weight hanging off the back. I am going to go with none If it breaks off I will just take up yoga
