What the heck is an alternator excitor switch or wire?
bsevans said:On a GM alternator it is a 12v wire that is used to turn on the internal voltage regulator. It is only hot when the ignition key is in the start or run position.
krzyabncanuck said:Are you rewiring something with a different harness ? If so i just got done with one myself using an EZ wiring harness, and i might be able to help you.
Degnol said:Good to know. I used to think that all alternators needed power to make power (unlike a generator) and the exciter wire energized the field.![]()
Ed
Pin_Head said:Both alternators and generators need "power" to produce power, because that is the way that the output can be regulated. The amount of power in the field windings and the alternator speed determine the power the stator produces. Whether the regulator is inside or outside the alternator makes no difference.
On my 78 the ground strap is bolted from the frame to one of the starter bolts. Run the output from the alternator to the positive battery post with 4 gauge wire (you can get this made up for you at Batteries Plus or make it yourself).mdjohnsen said:Ok. Now the harness instructions states for alt 80 amps or higher I need a "bypass" wire. Why? Also, there is a ribbon looking.....looks like it used to ground the body to the eng block or maybe to the frame. It's not hooked up anymore. Where does this go? How does a grounding system work in a vehicle?
