- Thread starter
- #41
Lift Gate Handle
Next came the lift gate handle, having already taken off the access panel on the inside I don't think this will be too hard, and over all wasn't.
Ran in to two issues doing this. First, as I almost always do, I dropped the washers, nuts, and bolts when I removed the remnants of the old arms. They feel down inside the lift gate. Was able to get everything fairly easily except for the nylon washer. No big deal, that can't be too important, right? Second, had a difficult time sliding the new handle through the slots for the arms. ended up taking a utility knife and shaving off a little of the old dried out rubber in the holes. Still tight, but as I'm thinking about getting some lubricant it slides in. Yeah!
Get it all back together (except for that nylon washer) and shut the gate for a test. It's stiff as can be. Play with it open as I watch from the access panel and it's rubbing where the nylon washer is supposed to go between the metal arm and the metal bracket it attaches to. Damn, now I need to dig that washer out and do it all over again. Spend a few minutes that I should have spent in the first place and dig the washer out from inside the lift gate. Put it all back together and it works.
All in all not too bad. Just have to stop dropping stuff all the time and take my time and do it right.
On a related not, the later model tire carry latch does not stay shut well without some aid (have a ziptie around it now) and is difficult to clear the bumper when I do open it. To fix the opening issue all I did was loosen the bolts on the bracket where the latch catches and slid it up, retightened the bolts, and now the tire carrier opens easier. Still have the ziptie on the latch (extras and cutters in the glove box) but am not too concerned by this minor inconvenience for the time being (in the long run plan on getter a bumper with the tire carrier mounted on it).
Below are the before and after pictures.
Enjoy
Enjoy
