The Window Regulator
Been awhile but I'm still around tinkering on the 40.
The latest things I have done (before Christmas) was replacing the window regulators on both windows, installing the handle for the rear lift gate, and taking care of the major draft coming through the dash.
The first one I figured would be the easiest, replacing the window regulators. Boy, was I ever wrong. Easy enough taking the old worn out regulators out, but that is where the easiness stopped. Took the new regulator and installed in the passenger side, the window would not go up all the way. WTF. Look at the bag it came in and it was for the driver's side. Problem number 1, the old window regulators were put in on the wrong door.
No problem (haha!). Grab the the other regulator and install it. the window now seems to catch on the way down. Dang, the bolts are too long. Problem number 2. Take out the grinder, put the bolts in the vise, and cut them short (had enough since to slip a nut down the threads so I wouldn't bugger them up).
Passenger regulator now works, even though a little stiff, but the handles seems a little close to the bolt heads. Good enough for the passenger side though. Go on to the driver's side and since I have all the problems solved it will be quick and easy. Remove the old regulator, cut down the bolts, and slide the new regulator back in. This time those bolt heads rear their ugly head. Problem number 3. Go through all my odd and ends bolts and screws and luckily I find one, only one, screw that is made just for this application. In it goes on the worst offender and problem solved.
Now I have working windows, even though they are a little stiff. Which leads me to my question, does it matter what door a particular window goes in? or are they interchangeable?
Thanks for sticking with me for the story of the window regulator. Below are a passenger side before picture, a driver's side after picture (with the lucky screw in upper right corner - not too good quality pic now that I preview it, oh well), and a pic of the old window regulators (wore out teeth and coil).
Enjoy
