- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
Good morning
Welcome to a new idea and new single source place for ANY Fusible Links Related Topics , including parts like Battery Terminals , Fuses , Technical Step by Steps outlined in the Factory Glove Box owners Manual and any FSM too , such as how to Safely and Properly use and apply Jumper cables to and from a Land Cruiser 40 & 55 Series , both DIESEL and Petrol ....
- The Mission Statement of this thread shall always be in the event of a worst case scenario , a Fellow MUD member is out there on the perimeter , where there are no stars , overlanding or off roading and should have a Vehicle Down situation Stranded NO START or PWR. due to Fusible Links Failure . ??
- Now has a Single Source Solutions Technical place that they can use and rely on to get up and running again , moving forward once again , buy Using and Applying the Correct FSM step by steps Confirm , Dianoise , and Verify philosophy mind-set approach ...
- the whole broad brush Fusible Links anything tipic can and is Confusing , bottom line ,,,,
- not to mention , TOYOTA has Disc. / NLA 100% of any replacement parts ..
- many good time tested needed parts solutions have been tackled and are currently right now available from the Timeless & Iconic @Coolerman , this is a good thing ......
- LINK to @Coolerman & Cruiser Wiring parts store is open 24 / 7 / 365 :
- the ones that are not currently Skunk-Work'd out , will be sooner rather then later ........
- -Lastly , as Thread Starter , i would like to Dedicate this place of OEM Inspired Solutions done correctly by the FSM , and to a Higher then High level of standards 24/7 to my life time Teq Electrical Jedi Technician Master @Coolerman , Thank you Sir ......very very much ....
- THIS IS THE WAY
- THIS IS THE WAY
